Old 11-24-2019, 09:53 AM   #16
particlewave
Originally Posted by PaulE View Post
Is this the relay wiring to flash the original high beam bulb that you put in the bi-xenon projectors you used to assemble? I'm going to try and build a set with some old craigslist headlights I picked up, now that I have successfully opened one of mine up to re-glue the projector lens into the shrould and re-sealed it. Thanks in advance!
No, Ger wants to use his low beams as flashers with the headlights off.
Yours is a bit different and simpler. I’ll get your diagram to you.
