Old 11-19-2019, 09:37 PM   #3
AZ986S
AZ986S's Avatar
Originally Posted by MaxD View Post
That looks like great bang for buck. Do you have one?
Like the Raspberry Pi option.
Yes, I have a Race Capture MK1 and dedicated oil pressure sensors with the Accusump. The rest of the parameters I log through the OBD2 adapter on canbus. If youd like more details I have documented almost everything. The new RC MK2 can now run shift lights and sync video cams over canbus and Wi-Fi.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
