Old 11-16-2019, 06:17 AM   #2
KRAM36
Need For Speed
KRAM36's Avatar
Clear alarms code? Do you mean clearing fault codes? Yes, the Durametric will clear fault codes.
You can use the Durametric to manually test some items, but I don't recall seeing a spot to test door actuators. You can run a system test on your car and it will lock and unlock the doors during this test. I've never had an issue with my doors, so I don't know if during the system test if it would pull a fault code for an issue with a door.
2003 Boxster S
