Is the top light on in the cluster, sometimes a malfunctioning top will cause this. In my car I pulled the double relay from the fuse box and the windows work fine. (My top is converted to manual)
The 986 headlight housing lenses burn real easy so you have to be careful what bulbs you put in them, especially LED as they can create a ton of heat
