Thread: IMS again
Old 11-10-2019, 02:48 PM   #2
piper6909
piper6909's Avatar
Yeah, the oil-fed solutions are changing the bearing to an open bearing, which requires constant lubrication. (iiuc)
For me, I wish someone would develop a replacement bearing that's more like a traditional crank bearing, with a direct oil feed to it, and bearing "shells". This makes so much more sense to me, and would have the happy benefits of still staying largely "in-place" if the bearing failed, si timing remains close, meaning no other parts in the motor get damaged. It would also be easily replaceable if damaged.
But that would be FAR too easy for the Porsche community.... Haha. I mean, it'd be almost sacrilegious to put a simple and robust bearing in a motor with 5 chains, all those ramps and hydraulic tensioners, the craziest Air/Oil separator system I've ever seen.... etc etc.
It's already been done, sort of, but it still uses an external oil feed:
IMS Solution – The only permanent fix for M96/M97 engines intermediate shaft bearing problem
I love how they call it the "Permanent fix" but only guarantee it for 5 years!
