Old 11-07-2019, 07:39 AM   #17
Dave2001S
Thanks so much for the helpful comments. I ordered a new oil filter canister with the hope that this may be a simple fix. I also took the step of adding the recommended amount of marvel mystery oil to the crankcase; just to see if there was any improvement. I have run the car only a few times thus far, and not on the road yet. Proceeding carefully, and a bit nervously. Seems to run fine at RPM's up to 3K. No audible tapping, no oil pressure light, no CEL. I plan to change oil and filter again, this time with a 10W40 or 20W50 oil (any suggestion which?). One question: the oil pressure relief valve you mentioned - is that inside the engine? Meaning, in order to check it or replace it, does the engine need to be removed and disassembled? Thanks again for the help.
Dave2001S is offline   Reply With Quote
