Old 11-06-2019, 07:10 PM   #30
Gilles
+1
It could be a stuck piston or 2, glazed pads/rotor, or bad brake hose. Either way, I'd concentrate on the front passenger side.
Yes, a glazed rotor or pads could cause this as well.
Some times you can remove the glaze from the pads by sanding them, but I don't believe you can fix a glazed rotor with sand paper..
PS: you could swap the front pads from one side to the other and measure the temp again
Gilles is offline   Reply With Quote
