Old 11-05-2019, 05:19 AM   #26
Starter986
1998 Boxster Silver/Red
+ 1
yep, JFP shared this tip on the forum and works perfectly, no mess and you will get it done right the first time!
I should have prefaced the method I employed by sharing that it was upon these pages that I learned that trick. Because I can't change a tire without first reading 50 posts I tend to over-complicate even the simplest tasks. Thus, it was when I was going to remove the oil pan I immersed myself in reading. I'm certain I spent more time reading about dropping the oil pan, a 2/10 on the difficulty scale, than it took me to do the job.
Many things I read were associated with the pan slipping around... having to clean off the just applied sealant... and starting over. More likely than not it was a JFP post that was my "ah-ha" moment, then going to AZ for those bolts... lopping off the heads... and getting the job completed, correctly, the first time.
I'm what some might call a $30,000 millionaire and, without the tips, tricks, and advice on these forums... I couldn't own the Boxster.
1998 Porsche Boxster
