Old 11-04-2019, 07:48 AM   #2
Gilles
your rubber? lines between the hard line and the calipers can have issues.
They can swell inside and cause problems with the brakes releasing acting like a stuck caliper.
Or they can soften causing them to swell when you apply the brakes thus less clamping force at the caliper.
From you description:
You may possibly have the second problem.
I had this issue before with the rear brakes on the Alfa transaxle, they were 'balloning' (blistering..?) under pressure, but otherwise look normal without pressure.
How old are your rubber brake hoses? You may want to replace them, as they do age and are not too expensive..
PS: just remember that I also had the same failure but with an old slave cylinder rubber hose (also on the Alfa..)
Gilles is offline   Reply With Quote
