Old 11-03-2019, 01:35 PM   #20
SMK Shoe
Originally Posted by JimmyBad View Post
I had the same issue once and I also had an aluminum plug, so I went to the auto parts store and bought a flat head chisel. I used to work at a quick lube shop, so I went under the car and hammered the chisel at an ideal angle where it would not break anything but have enough bite to get the plug rotating.
Started doing that, and will probably end up doing it. I just didn't want to get too destructive until we had replacement parts on hand. Did not want his Boxster up on the lift for a week or two while he sources parts. Once a new drain plug, oil pan, gasket material and oil are here. then we can get progressively more aggressive. It is drivable now and will be for a few thousand miles until next oil change is needed.
SMK Shoe is offline   Reply With Quote
