Old 10-28-2019, 01:10 PM   #4
Blue99
Hi you never ‘ top up ‘ a system. You take out all remaining gas , vacuum the system to remove moisture then refill with the correct weight of gas in grams ~as in 750g etc.
If moisture is not removed it can freeze at the very least causing a restriction
Most of these cans cost £45-50 most indys will do a proper job for that money
Blue99 is offline   Reply With Quote
