Old 10-28-2019, 01:01 PM   #1
Seadweller
I would not recommend it. Actually, I wouldn't use anything like that on ANY car, unless I started with a completely discharged and vacuumed out system.
The problem with using those is that there's supposed to be a certain amount of refrigerant in the system. In weight, not pressure. So if your system is low, you're adding blindly and run the risk of overcharging the system.
Thanks, I may have used the term "recharged" incorrectly. Perhaps "topped off" to raise a low refrigerant level would be more accurate.
Is there still a risk of overcharging in this case? If I have my INDY do the service, will they proceed any differently, albeit perhaps with a better set of gauges?
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is offline   Reply With Quote
