Old 10-24-2019, 03:14 PM   #1
cc986
Door handle works on second lift up
My 2001 986 has a driver's side door handle problem that has slowly gotten worse over the past few months. After it has been locked and unlocked (key or remote), I have to gently 'jiggle' the handle a little bit in order to hear/feel a small 'click' that tells me that a pull up will open the door. Otherwise, the first pull up acts as though the car is still locked (even though the window drops a cm), but it will open on the second pull up.
I am now extra careful to try the jiggle technique first, because the two-pull method is putting extra wear on the window motor as the window moves down even on the first non-opening pull.
Sorry if this is a repeat of a common theme, but I've looked through a lot of 'door latch' issues and none seem to be quite like this. Thanks in advance!
cc986 is offline   Reply With Quote
