Old 10-23-2019, 12:56 PM   #2
Gilles
Originally Posted by gabedrummin View Post
Mine is leaking like crazy.
Gabe, you may want to clean very well the area where the both of the hydraulic fluid tubes connect at the steering rack, as they have an o-ring (one each) that is very easily replaced, but those would make a mess if not sealing properly.
They are very accessible, if you remove the front driver side wheel they will be right in front of you, hopefully this is the cause.
Good luck!
