Thread
97 boxster
10-23-2019, 04:54 AM
bmaharg
97 boxster
I just purchased this and have replaced the tires (Nitto Motivo) and done an air filter and oil change. I am putting a feeler out there as I am not sure if I want to invest the time into this or sell it and buy a 987 instead. It has 87k miles and runs great, but it needs some help. Here are the known issues - The struts need to be replaced, there may be some other suspension pieces that need refreshed (i.e. ball joints and strut mounts). The convertible top is manual, I believe the transmission gear is stripped (known issue), it works fine but has to be done by hand. The a/c does not work. The interior could use a solid cleaning. There is a vibration noise when holding speed - this could be a heat shield, motor/trans mount, or something else. The drivers fender has a decent dent it it and there are a few other small dings. It does run great and has low miles for the year. $5500 with the hardtop or $4700 without. Currently Pending sale on a PPI
Images do not seem to be working, check here for photos:
https://imgur.com/a/Xy1KIK1
12:51 PM
. Reason: Pending
bmaharg
Find More Posts by bmaharg
