Old 10-20-2019, 01:15 PM   #10
speedyspaghetti
Originally Posted by rexcramer View Post
I found these drive cycle instructions somewhere online and have used them successfully for my 97 twice.
Do you know what monitors are showing as not ready? If you have an OBDII reader you can plug it in and it will show you what monitors are not ready. I had a problem with my Oxygen sensor monitor and followed this drive cycle and it cleared..GOOD LUCK!
Below we outline the driving pattern you'll need to perform in order to get your Porsche's OBD-II emission monitors to become READY or COMPLETE. Perform the entire drive cycle. Completing only one portion of the drive cycle will not make the particular monitor which you're trying to make READY complete. The entire drive cycle must be performed every time you attempt the set any of the monitors.
Porsche 911 Drive Cycle - OBDII Emission Monitor Reset Procedure
Prior to starting the driving cycle ensure your Porsche's fuel tank is between 1/4 and 3/4 full. Also do not exceed 3,000 rpm or 60 mph during any portion of the drive cycle. Take extra caution when perform the Porsche drive cycle on public roadways. if you think you will be unable to safely perform the drive cycle please seek assistance from an experienced Porsche mechanic or smog check repair center.
A. Start your Porsche 911 and let it idle for approximately 2 1/2 minutes. This will allow the ECU to diagnose oxygen sensor aging; meaning the computer will be monitoring the oxygen sensor warm-up period and reaction to rising exhaust temperatures. During this period the ECU is also testing the Secondary Air Injection system.
B. Begin driving. Accelerate to 20-30 MPH and maintain your speed for 3 1/2 minutes. The ECU will be testing catalytic converter efficiency.
C. Next, accelerate to 40-60 MPH. Once again maintain steady speed, this time for approximately 15 minutes. The EVAP system is now being tested along with adaptation range (2) and the oxygen sensor (switching).
D. Decelerate and come to a complete stop. If equipped with a manual transmission, idle in neutral for 3 minutes. If equipped with an automatic Tiptronic transmission, idle in drive (D) for 3 minutes. Adaptation range (2) is now being tested.
E. Repeat steps B through D. Drive cycle complete.
I followed the instructions provided by the San Diego PCA Tech Advisor and it worked
Drive in 10 minute cycles 1400-2800 Rpm in 5-6 gear as slow as you can drive in light traffic.
If you stop or go out of RPM range the cycle resets the timer.
After 5-6 cycles you will probably have it.
For evap you must have 1/3-2/3 of a tank of fuel.
Start the car cold and let it idle for 10 minutes with lots of accessories on. (lights, A/C or heater)
Do the same at the end of the drive cycle.
It took 3 cycles of slow freeway driving to get it reset
I drove in 6th at around 58 MPH
People were looking at me oddly driving a Porsche so slow!
Thanks for the crazy detailed post! The monitors that are still not complete are secondary air injection and evap. I've done the first drive cycle, but so far only the catalyst monitor completed while doing that. I'll try the second one you mentioned as well.
'02 Boxster S
'16 FR-S
'01 M5 (sold)
'07 Mazdaspeed3 (gone)
speedyspaghetti is offline   Reply With Quote
