Old 10-15-2019, 09:36 AM   #29
blue62
Simple: It is better for the oil, and for the engine. In spite of your research, the only reason the factory run these cars so hot was emissions, period. Back when LN first introduced a 160F thermostat, we collected data on UOA's in cars before and after installing the thermostat. Net result was that nearly all of the oil values (film strength, TBN, viscosity, water content, fuel content) were excellent for longer run times on the car running the cooler thermostat. We saw absolutely NO increase in either fuel of water contamination in oil samples, and oil quality was much better for many more miles. We have also seen no change in O2 sensor life or performance, or in cat life expectancy. And contrary to your data, oil temps in these engines are typically much hotter than 195F when running the OEM stat; 225-235 is more like it.
As for fluid warm up, your data is also suspect. How fast an M96 heats up is a function of the engine's specific heat out put rate at any given ambient temperature; the thermostat functions just like the one in your home: Regardless of where it is set, how fast the temperature rises is constant, only the point at where the thermostat takes control and throttles the system changes. Fully instrumented M96's warm up both the oil and coolant at the same rates, regardless of which thermostat is in play. Only their final "steady state" temperature changes.
You might also be interested in the fact that every turbo, GT2, and GT3 car left the factory with a 160F stat in them...…….
JFP
Glad to see you jumped in on this.
Yes it seems all car manufactures number one concern is emissions everything else being secondary.
The primary reason modern day cars run hotter then pre smog days.
Interesting data you collected.
Good information to be considered.
Always trying to broaden my knowledge base.
I wonder if your findings are relatable to most modern day cars???
That would be interesting information
blue62 is offline   Reply With Quote
