Old 10-12-2019, 05:43 PM   #12
blue62
With those two trouble codes, P1128 and P1130, the AOS is also suspect.
There is a spec for vacuum at the oil filler cap. It Has to be read with a manometer as a regular vacuum gauge is not calibrated fine enough. I do not know the spec but if it exceeds the spec then the AOS is suspect. This info has been posted by member "JFP in PA" so if one does a search you should be able to find the info.
