Old 10-12-2019, 03:40 PM   #1
BoxMann
Re-Installing Climate Control Module
I removed the Climate Control module a few days ago, sent it out for a refurbishing and LCD replacement. Took 5 minutes to remove, piece of cake. So far so good.
So today, I get the rebuilt unit back and I can't re-install it. There are two white plastic brackets that slide onto the side of the unit on a rail with a retainer at the front where the screws screw in to. If you put the brackets on the "rails", you can't maneuver the unit back into the opening, or at least I can't figure out how to do it.
Anyone know the trick here? Keep in mind this is a '04 Boxster which has 4 mounting screws. I think most of the others have 2 mounting screws and install somewhat differently.
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
BoxMann is offline   Reply With Quote
