Looks good, nice buy on the wheels & tires. One issue with the current Toyota radiator set-up that I don't like is that the fan blows directly on the brake reservoir and ABS unit. I don't know if it's hot enough to really be a problem, but it worries me. I'm going to cut a section of aluminum heat shield from the piece that goes over the transmission and use that to deflect the air across and up. If that doesn't work, just mount a fan on the other side instead.
