I got my coolant pump set-up from Davies Craig out of Australia. Very nice machining and seems fairly straight forward but lots of control items to sort out if I'm using that controller and the factory ECM and the stand alone ECM. They all need to be able to run the cooling fans. Gotta make them all talk nice to each other.
Still researching ECM's. And intakes. Will likely need to convert to a cable operated throttle. Too many options but leaning heavily toward the Fitech unit.
The adapter from kitcarchassis.com is taking longer than anticipated but they had issues with their machinery. Stuff happens! Should be on the way this week. Fingers crossed.
Once I get the adapter I can bolt everything together including the balancer pulley and get going on mounts and clearance issues.
And now, back to the show!
