Old 10-07-2019, 09:15 PM   #7
mgfranz
If you do a quick search, you will find that the door latch used on the 986 is the same one used on many VAG cars and can be easily modded to fit the 986 for under $40 new. The biggest thing is to make sure you get the right pin connector for your car, some use 8 pin, some use 9 pin.
There are a couple DIY pages out there, I did my driver door with a $37 OEM VW part, passenger is about due.
mgfranz is offline   Reply With Quote
