Old 10-07-2019, 08:25 PM   #1
Pepik
Originally Posted by JustinS View Post
Check the relay to see if the ecu is triggering it. Maybe you have a bad relay?
Thanks for the suggestion, but I've replaced the relay and tested the signal at the socket with my multimeter with the relay removed.
Hmmmm, I think I'll double check, it's been a few weeks since I measured, and the more I think about it, the less I'm sure I checked the right pin. I'll update if I was wrong about the signal.
2002 Boxster S 7/2017 totaled (rear-ended) 11/2019
2013 Boxster S 12/2019
Pepik is offline   Reply With Quote
