Old 10-06-2019, 06:24 AM   #2
M9G
2002 2.7 Boxster in green
M9G's Avatar
Originally Posted by John Thomson View Post
Looks great..........what head unit/trim piece did you use?
John
The head unit is by Xtrons, this is the third car ive fitted an Xtrons unit in and they are really good. This one is the TA7091PL - https://xtrons.co.uk/double-din-android-9-0-ta709ipl - look on ebay as the same unit is cheaper and its from Xtrons using a different ebay seller name.
The cage is from a company called Connects2 who I use for all my cages and harnesses for double din head units. They have a great back up customer services aswell.
The ebay seller for this cage is Dynamic Sound who is the official distributor for Connects2 - https://www.ebay.co.uk/itm/Car-Stereo-Radio-Double-Din-Fitting-Kit-Fascia-Panel-Adaptor-Black-for-Porsche/352465150023?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Also the harness came from the same company and the only wire I had to install was for the illumination of the head unit which I took from the feed for the bulb on the cigarette lighter. This harness is for a boxster with built in amp but NOT fibre optics - https://www.ebay.co.uk/itm/CT53-PO01-CD-Wiring-Loom-Harness-Active-System-Adaptor-For-Porsche-911-Boxster/401631954462?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 .
They also do the harness if yours does have the fibre optics
It was all really easy to install and only took a couple of hours. I do have a reversing camera to fit which I will do one day
Regards
M9G is offline   Reply With Quote
