Old 10-04-2019, 04:35 PM   #2
piper6909
piper6909's Avatar
Originally Posted by Jerry1847 View Post
Need help please. No luck with searches.
2001 boxster s 6 speed
Had the car up for a couple week to replace the high pressure power at hose, oil change and trans fluid change.
Had to remover the belt and intake tubes. Now I have no throttle response at all and the idle is inconsistent.
Any thoughts? I did the 1 min on,10 sec off and start, also disconnected the battery. I couldn't find anything unplugged or broken.
I was unsure of the vacuum line routing but think it's correct after reading up on diagrams.
I'm pulling codes for pedal signal and mad throttle position.
Go back and re-trace your work. It seems like the electrical plug going into the throttle body may not be plugged in or not in all the way.
