Old 10-10-2006, 10:59 AM   #4
deliriousga
deliriousga's Avatar
Originally Posted by jraben
Yes i do.........
Then it sounds like one of your door switches is not working properly. First make sure your middle console is closed completely (clicks) along with gas door, both trunks and doors then use the remote to lock the doors and see if you get the beep. If you do, open one of your doors and push the button down that normally turns the lights off. Twist it some to see if it can make contact and push it in to see if the lights go out. If not, try the other side.
If that doesn't work, you could pull the alarm codes with the durametric tool if you have it or know someone who does and see if there's something up with the alarm/locking system. I don't think there are any relays for the interior lights so I'm not sure where to go from there. Hopefully Tool Pants has run into something in the past that can help you out.
1966 Wife White/Brown Top
