Old 10-03-2019, 05:04 PM   #1
maytag
Who's askin'?
maytag's Avatar
Honestly, to date, I'm quite happy with my grunge solution. Im using the stock AOS. I took a hunk of clear, braided, wire - reinforced hose and used it to replace the short hose from the AOS to the plenum. I made a single "coil" of it, that falls well below the intake.
The net effect is that when oil that would normally overwhelm the AOS and end up in the intake gets into the hose, it drops to the bottom of the coil. Because the hose is clear, I can see when there's oil in it, and I pull it off and drain it.
It's worked well SO FAR.
