Old 10-03-2019, 02:40 PM   #1
Jerry1847
Need help. Not pedal response, funky idle
Need help please. No luck with searches.
2001 boxster s 6 speed
Had the car up for a couple week to replace the high pressure power at hose, oil change and trans fluid change.
Had to remover the belt and intake tubes. Now I have no throttle response at all and the idle is inconsistent.
Any thoughts? I did the 1 min on,10 sec off and start, also disconnected the battery. I couldn't find anything unplugged or broken.
I was unsure of the vacuum line routing but think it's correct after reading up on diagrams.
I'm pulling codes for pedal signal and mad throttle position.
Jerry1847 is offline   Reply With Quote
