Old 10-03-2019, 03:34 AM   #8
itsnotanova
I've always thought that driving with a weak/bad AOS leads to an early death for the cats. Penetrating lube and some heat works pretty good to loosen the bolts up. I also recommend not using an air tool to remove them. You need to take it slow so you can feel if they're not turning. Sometimes tightening the bolt before loosening helps. I've also had to go back and forth a few times.
Woody
