Old 10-02-2019, 08:59 PM   #20
shacky
Shacky
No. There is constant, switched and ground, that is all you need. If it doesn't turn on and the fuse is good then it's time to replace it with another oem one or aftermarket. If replacing with aftermarket it might be best to take it somewhere and have them do it. If going with oem make sure you get the radio code also and it will be plug & play.
Ordered Alpine from Crutchfield 😉
shacky is offline   Reply With Quote
