Originally Posted by Stl-986
did you test the fuse in the panel with a meter? The key is on when you tested the wires at the radio and you tested red to ground, yellow to ground?
Yes key on engine running. I stuck ground lead in radio cage. Will check mail fuse again but it was fine as that was first thing I checked.
Radio sleeve in dash is grounded isn’t it?
