Old 10-01-2019, 04:58 AM   #12
Rob175
Rob175's Avatar
After I replaced the water pump....two weeks later the coolant tank in the trunk began leaking. But in my case it was a very slow leak the never got the carpet in the trunk wet BUT when I pulled out the trunk liner and lifted the raised floor boards in the trunk there was a nice big puddle sloshing around in my trunk......a new coolant tank solved the problem. Between the water pump and the coolant tank I spent $2,000 to have my "indy" replace both. Check your trunk, especially if you smell coolant while sitting in the car.
Rob175 is online now   Reply With Quote
