Old 09-27-2019, 02:49 PM   #25
blue62
Originally Posted by Vtx531 View Post
The MAF came today. I stuck it in and drove it around with the scanner.
Everything seems good! I don’t want to declare yet that it is fixed but I think it is. Power is good. Fuel trims are good.
I didn’t bother to check the brake booster because it was raining and I don’t think I have any braking problems. I was going to pull the vacuum line out of the boostrer and stick my finger over the end of it while watching the fuel trim. If it is the booster then the short term trim should immediately start to slew downward with the end of the hose plugged and leak stopped.
Sounds like a positive result to me.
Clear the codes out an continue to monitor.
Check for pending codes now and then.
