Old 09-26-2019, 03:59 PM   #1
DMags
98 Auto Tiptronic wont shift or park...hElP
Hey all, here is the situation. I picked up a 1998 Automatic Boxster with a Carrera GT body on it. Its Been sitting for about a couple of years now. I finally got the all the chewed up wires spliced, immobilizer and a thousand other items fixed up to the point then engine runs perfectly. BUT, It will Not physically go into park or make any of the gears do anything. so I have replaced the Neutral Safety Switch and the brake lock switch and still have the same situation. I pulled the gear selector and shift cable - they look fine. I tried to put it into gear by hand by moving the lever and neutral safety switch manually, but same result. It just wont go into drive or reverse. And I cannot match the neutral safety switch up with the park position on the trans lever(see pics).!?
Does anyone have a clue on this one?
DMags is offline   Reply With Quote
