lots of tutorials on youtube how to remove and replace
had a challenge with the two sided tape not quite sticking and broken plastic channel that holds the rear spline down across the roof so left it off - understand that new replacement roofs don't use that 'rear' spline vs only using the front spline if that makes sense.
marine guy sewed the rear window double stitching.. cut off of the original and thus keep the shape almost perfect. was a little tight the first few times to close the roof and need a little tug.. now working fine and waterproof... cost $100 local dollars (Canadian) and got quotes of $250-700 just to cut and re stitch the rear window with me supplying the roof in hand (no removal or install time or cost)
