Old 09-24-2019, 05:37 PM   #6
maytag
Who's askin'?
maytag's Avatar
Originally Posted by Anker View Post
Or spinning 180 degrees without both feet in! Can happen on track and in autocross. Important to do full brake and full clutch immediately when you spin, otherwise the car will pull the engine backwards when you roll backwards after the 180.
No, see, now you're off in lala land again, Haha. If it spins backwards under those conditions, then your tensioners are still pumped up, and no contact can occur. I've tested the theory, inadvertently.
I can tell you what WILL happen though. ;-)
maytag is online now   Reply With Quote
