Originally Posted by Racer Boy
Have you checked your front brakes? Loose caliper bolts? Pad mounting hardware allowing the pads to clunk around in the caliper? You'd think that a creaking noise wouldn't be brakes, it would be a clunk, but it's easy to check.
The pads where changed one month ago. Did take the brakes apart yesterday, didnīt notice anything strange, bought new caliper bolts and torqued those to spec.
Wishbone is not moving in relation to LCA-casterpuck (according to the nail polish), the wishbone is old, so the balljoint end might be a suspect.
When the wheels are braking, the wishbone takes the load from the LCA, but I guess the steering rods/steering rack takes the load from the wheels (other ways they would turn) so maybe this is also something to look into.
