Old 09-23-2019, 11:18 AM   #14
Vtx531
VTX531
Question?????
When you did the smoke tests on the car did you remove the MAF sensor?????
They can be very sensitive to contaminants.
I did not, but I removed the pipe between the MAF and throttle body and introduced the smoke at the throttle body.
****I think (hoping) the problem is solved****
I disconnected the battery for about 1 minute, pressed brake, reconnected, and did ignition on for one minute and off for 10 seconds.
This cleared the codes and reset the long term trim to zero. It ran great right off the bat (unlike before when I only cleared the codes using the scanner). Numbers seem good now at idle and when revved.
Idle:
STFT1 +3.13%
STFT2 +2.34%
LTFT1 -0.78%
LTFT2 -0.78%
Vtx531 is offline   Reply With Quote
