Old 09-23-2019, 03:03 AM   #10
blue62
Originally Posted by Vtx531 View Post
Replaced AOS with genuine Porsche unit. CEL is back P1126 P1133. Maybe another smoke test is in order but it seems like it is cutting out and hesitating when under load and snapshot showed CEL triggered at 18.8% load.
Any thoughts? Perhaps I need to run some graphing software to see what is going on at higher loads
Latest snapshot:
P1126
Sys1 CL
Sys2 CL
Load 18.8%
ETC 187 degrees
Sft1 19.5
Lft1 28.9
Sft2 18.0
Lft2 26.6
Rpm 2440
Vss 45
Prior to replacing AOS and resecuring the boot I was getting P1128/P1130 triggered with P1126/P1133 pending.
Prior snapshot:
P1128
Sys1 CL
Sys2 CL
Load 2.0%
ETC 226 degrees (had overheating issue that is now fixed)
Sft1 -3.9
Lft1 14.1
Sft2 -4.7
Lft2 13.3
Rpm 680
Vss 0
The original code/snapshot looks like a classic vacuum leak but the new one maybe a MAF sensor?
Any help appreciated!
Your current snapshot and the fact that you have hesitation under load suggest a vacuum leak.
I would buy a vacuum gauge (about $20.00 at most auto parts store). and do an intake vacuum test. Should read 18-22 on the gauge with a steady needle at idle.
That will prove out yes or no on the possibility of a vacuum leak problem.
If you suspect a faulty MAF sensor unplug it. Take the car for a short drive and see if that improves engine performance. If it does then the MAF is faulty, if it doesn't then most likely the MAF sensor is not the problem. But the wiring to the sensor could be.
Your latest work on the AOS could be related to your current codes. double check your work. Make sure everything is connected correctly and that you didn't knock some wiring or vacuum hose loose in the area of your work.
Since your car is a 2001 it has E-gas throttle (drive by wire) after you disconnected your battery did you recalibrate your throttle when you reconnected the battery???? Before starting the car.????
