Thread: Dronefactory
Old 09-22-2019, 05:54 AM   #8
Gilles
Originally Posted by Vtx531 View Post
"Quote: Use studs on the Trans mounts and space the mount out using nuts and washers.. It will lower the tips from the rear bumper"
Im not familiar with exactly what you mean but I will take a look and see. Thank you
When you get under the car you will see that the exhaust is supported by a bracket that is attached to the rear of the transmission, if you lose the ALL the bolts at both sides you should be able to move the exhaust a bit and fine tune it's position, you may want to apply something like PB Blaster to the hardware a day or so before to loosen the rust, etc.
God luck!
Gilles is offline   Reply With Quote
