Old 09-20-2019, 08:30 AM   #6
particlewave
If the fork was never changed, it is definitely suspect. Cracked forks are a much bigger issue than a failed pressure plate (actually, I don’t think I’ve read of a failed pressure plate on a 986, other than surface wear).
There is a revised fork that replaced the earlier forks that were cracking, IIRC.
