Old 09-20-2019, 05:02 AM   #19
djw8282
djw8282's Avatar
What happens if you put it in second gear, start it with clutch depressed, then let off brake with clutch still depressed (on flat ground)?
Does the car try to creep forward at all (is the clutch grabbing at all with the pedal fully depressed, in gear and running)?
Hey Particlewave, I appreciate the response.
From what I remember, yes the clutch is grabbing. I did start the car in first and second and the wheels would spin as I let off the clutch pedal. Right now the rear is on jack stands but I will try again when I get home from work. Again, thanks! If this is the case, what do you think?
djw8282 is offline   Reply With Quote
