Not sure on the bleeding process, but would it be worth going through again? Not familiar with the clutch system, could it be the master cylinder (if there is one)? The car does shift when not on, but are you sure it's fully going into gear? Yes, the shifter may be going full range, but if the cable slipped, it may not be going fully into gear. Could this contribute?
