Old 09-18-2019, 10:15 AM   #685
Ben006
Ben-Auto-Design
Ben006's Avatar
Hi guys, have you been able to download the instructions from Wetransfer ?
Yes, the hole is already 10mm with two flat spots. You have to remove the flat spots, then drill further at 10mm to make room for the long bolt.
It's how I intended to work, but it might be just fine if you drill it at 12mm and let the bolt go through !
The problem I see with that is that the nut won't be tight, and if you try to tighten it too much it will bend or break the plastic base.
Drilled at 10mm
Bolt goes through but stops on the first plastic wall :
Nut is tight against the wall that is against the bolt' shoulder, there is no play.
I hope it's clearer now
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
