Old 09-18-2019, 03:01 AM   #684
rfuerst911sc
Originally Posted by Terryg View Post
Mine said that 15/32 was slightly smaller and since the whole point of the lever is to minimise slack I thought I had better ask, I am nervous that a 12mm drill bit on plastic may come out slightly more, I'll keep the speed down or maybe drill smaller and ream it out.
Thanks,
Terry
If you can take any scrap plastic you might have and drill the 12mm hole and check for fitment . If too large then your idea of drilling smaller and reaming out is a good one . In my case 15/32 was tight I had to work the bolt to get it in which is what I wanted to eliminate any excess play .
rfuerst911sc is online now   Reply With Quote
