Do you have TCS on the car? If you're getting into traction control you should see a flashing yellow light on the lower part of your dash.
Does it happen only when turning one direction, or regardless of the direction you're turning? Does it happen when braking hard in a straight line? Have you put it on a lift and taken a look for any rubbing marks around axles, wheel wells, motor area?
