Ugh, with all the direct wiring harnesses avail now why do people still cut off original plugs? Drives me crazy! Probably the only thing you could do is find a junked car and cut off the stock plug and rewire. Look up a couple of the guys here parting out cars, would be a quick and easy snip. Then buy the correct harness adaptor for whatever aftermarket system you put in. Or, as it’s already cut, do as above and get the wiring diagram. Good thing about finding the stock harness is the wiring should be an easy job.
