					Originally Posted by  robdelorenzo
				What dilution/ratio (or simply how much) for either Simple Green or Shout?
With the SHOUT I'd go 1 part SHOUT... 10 parts water. Buy a couple jugs of the SHOUT (I believe 32 oz each container)... mix it with the water... run it through... drain... repeat another time or two.  Rinse the system. Drain. Do that until the plain water starts draining clear. Then a solid rinse with distilled water. Drain... fill with the regular coolant/water concoction.
Best wishes.
