If changing the fuel pump relay has no affect then-
Check the wiring from the DME to the fuel pump relay for a short to Battery positive.
After that if you have a scanner that will show it????
I think you can hook it up step on the throttle and see the % the throttle opens.
That should prove out if your throttle is the problem or not.
Much better then taking things apart if you don't need to.
