Old 09-15-2019, 10:48 AM   #15
blue62
If changing the fuel pump relay has no affect then-
Check the wiring from the DME to the fuel pump relay for a short to Battery positive.
After that if you have a scanner that will show it????
I think you can hook it up step on the throttle and see the % the throttle opens.
That should prove out if your throttle is the problem or not.
Much better then taking things apart if you don't need to.
blue62 is offline   Reply With Quote
